benslgdroid
rockstar
If advanced can't locate it then I'm sorry to.say its bricked. There's nothing else I know that can be done Andy says the same.
This wont work in emergency mode,or recovery mode.
It's got to be done with the phone turned on from power off state. Doesn't matter if it's looping.
To thedoode365: when you first established ADB where you able to give your phone commands?
If yes, what is the path to your adb.exe?
If no, delete everything having to do with the adb. That's SDK and the drivers and the whole shooten match.Then use the ADB installer I linked you to.
I also need help i got the # in the command prompt where do i go from there?
A few posts back Andy put a bunch of links those are all tutorials to get you where you need to. Try reading those first. What exactly is wrong with your phone?
