Not sure if this is the place to post this but I have a question regarding battery drain and the new update. I was on zv4 and battery life was great. After updating to the latest version (rom and radio) my battery drains very fast and my "time without signal" is always in the high 90 percent range. I have rooted and installed many custom roms on all my all my phones over the last few years but I still dont know any of the "behind the scene" stuff. Is it possible to reflash just the radio from the previous version? do you think it would make a difference? or might it just be a coincidence that I am getting high battery drain after updating? If it helps I did try ##72786# and then reactivated but no change.
thanks in advance,
allen
I'd try reflashing rom and radio. My battery life averages 2 to 3 days depending on usage.
How long has it been since you upgraded? Try charging with phone off one time and see how it goes.
You can try to recalibrate your battery.. Apps in the play store make that easy. Just charge to 100 and run the app, sometimes this will work too.
Downloads:
Odexed - ZV5_Odex_Rooted_Debloated
Odexed Rom MD5: 6ea37f6f78af33d823dcc7e0c86657bf
Deodexed - ZV5_Full_Rooted_Deodex
Deodexed Rom MD5: 611108a5bd785952bb38a8c97b8503fb
This.is anyone one else having a problem with the link? both links give a 404 error.
thanks in advance,
allen
I'll keep an eye on the thread for whenever they're uploaded. Thanks for the timely response.Sorry guys I'm uploading new builds. I fixed the odexed ROM and added the preload apps back in. I should have links back up later tonight. After that there will be a full odexed and full deodexed zv5 ROM.
Thats the kind of battery life I was getting on zv4. Might try reflashing zv5 again.
I have to disagree completely with this. Clean Master is not a way to fix anything. I would rather see you use this:Before you reflash everything, try this:
I was having the same issue and the steps below outline what I have done to fix it. If you notice unusual battery drain later on, it is most likely due to new apps that have not been blocked, so just repeat these steps,
1 - If you have not already, install Clean Master from the play store.
2 - Grant it super user permissions.
3 - Click on the "Phone Boost" tile
4 - Find and click on "Autostart Manager"
5 - Let it run and then block all unnecessary apps from starting on bootup and in the background by switching them from on to off.
6 - Your done!
7 - Repeat as necessary (when you install a few new apps)
Hope this was of help! I've blocked close to 40 apps and my battedy is now lasting a full day (I'm a VERY HEAVY user, so that is spectacular for me)
https://play.google.com/store/apps/details?id=com.rs.autorun
Before even that though, try Snapdragon Battery Guru. It's a battery/phone manager made by Qualcomm specifically for the Snapdragon processor. You can also use Greenify to identify apps that are using up your battery and have it block them.
Thanks Jamorrow, i really appreciate this!From that zip the BackupRestoreConfirmation.apk LGBackup.apk and LGMemo.apk all go in the
system/priv-app folder and the LGMemoWidget.apk goes in the system/app folder
My time without a signal is always high, it's currently at 98%, but that may just be due to being on Wi-Fi most of the time. I still get over 2 days worth of battery. I'm currently at 77% after 13 hours off charge and estimated 24 hours remaining, which will increase overnight when it's just sitting idle for 8 hours.
You can flash the zv4 radio if you want, it shouldn't be an issue. A factory reset might also help.
