i tried to do a back up restore to the phone and it says their is a mismatch! this does not look good
no you a simple data reset will not lose root ,,,,it just clears stored data for system and apps ,the way you get back to stock is to flash the .2.3.340 full sbf or use maerstok.zip through bootstrapit finally loaded (sigh of relief) but i did lose all my data. do i need to redowload all my root stuff? and is there a possible way to go back to stock now?
and here is where you went wrong my friend and how you got stuck in a bootloop in the first place ,,,,do not cut corners on this stuff its very important to follow the devs instructions they are there for a reason,,,,im glad you were able to get it squared away ,,,if you need those files i mentioned let us knowi just dont want to have to factory data reset the phone
I still don't understand what's so bad about a factory/data reset to everyone
it doesn't take *that* long to set up all of your settings again
in fact, I'm getting quite fast at it
