Wait for Lineage is up!The official download link is dead (download.cyanogenmod.com refused connection).
I dofile manager cant access micro sd
"this operation require elevated permissions. try changing to root access mode"
well its already root access mode by default... and i tried install supersu... no luck still error
anyone facing the same?
 ress VolUp button and then connect USB cable
ress VolUp button and then connect USB cableNow I got purple screen and to fix that I need this fileI even dont know where to find it. Anyone have some idea what is it and how to get it?
File is on the 1:46 min!
I have the same error when trying to flash RRWhat is Error 6
This is new TWRP 3.0.3
You need to flash aboot.bin for your specific L70 variant(D320/D320N/D325/D325F8/MS323). There's an "Aboot dump thread" in this section. Search for it.How did you get the purple screen? I have gotten that screen twice last month when I was using normally the phone, and the only thing I did was to reset the phone pressing the power button 20secs
I installed TWRP 3.0.2 again and was able to install Lineage OS build 2017-01-26, I have not tried installing with version 3.0.3.The installation structure is different from the one that has been present since CM12.xx.
It has a system similar to what was used until the CM11.xx
That is: it does not use the scheme to flash by block image update the system images "system.new.dat" and "system.patch.dat". The script does the installation by package extracting dir "system folder", creates the symlinks, flashes the kernel (boot.img) and, it seems that it is trying to apply a patch to the recovery that is installed. I think it is plausible to install LineageOS Official ROM with CM recovery (suggested by vm03) already installed.
Obviously, this patch is not appropriate for TWRP. And, it may be the cause of the "DBI error" pink screen.
I believe that this mode by package extract dir of "system folder" makes it easier to customize ROMs based on LineageOS.
I just analyzed it and did a comparison.
I have not installed it yet.
I will analyze some more versions still.
I always had in mind the attitude of doing the first tests when the list of bugs between versions begins to reduce.
