Use TWRP 3.0.3how i can install lineage recovery so I can auto update?
can you give link to lineage recovery for d325?Use TWRP 3.0.3
Yes. With TWRP 3.0.3 OTA works.can you give link to lineage recovery for d325?
edit: could you clarify if you mean we can OTA with TWRP 3.0.3?
Thanks, broYes. With TWRP 3.0.3 OTA works.
Nop. WiFi has not failed me. I have the latest version of Lineage OS.Does anyone know why the wifi stops working?
Hi,
All ROMs I own, do not install through TWRP 3.0.3-0.
I've tried all the methods. Always checking if it was not set to read-only on the system partition.
Clean installation attempts ... were frustrated.
It's bad news, in my case.
The good news is:
I'm using the 2017-02-15 version.
In the d325f8 model, it was only possible to install using the @ vm03 method (flashing the experimental, doing the complete reboot, reboot to recovery, and flashing the nightly), through TWRP 3.0.2-0.
I ask the owners of this model to report if it is the same with you.
 )? Will there be possible for a rom that addresses the NFC issue, or is it unachievable?
Hello again, i installed new rom 23.02 and for now i love it, its perfect
Sorry bro i dont have problem with wifi and 3gWhat about the WPA-EAP wi-fi security protocol?
Is it working for you, @stevce80?
Is it working for someone?
The problem I'm having here. It does not save the SSID network. When selecting the "802.1x EAP" protocol, the "save" or "connect" button is disabled.
I have to manually edit the file "/data/misc/wi-fi/wpa_supplicant.conf"
Does anyone know how to fix this?
This function in a D320G8 LG room?
May someone reply if it works on the LG L7 D320G8?
if you have cm14 you can try flashing LOS 14May someone reply if it works on the LG L7 D320G8?
I use sd as internal adopted storage without problems, but when i update i use twrp 3.0.0 tryI have a problem, having the SD adopted as internal storage, the device stays black screen. Removing everything works well. Does anyone know if there is a solution for this? Since I have had to format SD several times in order to use it.
Thanks, i will tryif you have cm14 you can try flashing LOS 14
