Root LineageOS 14.1 for LG L70 D320 D320n D325 MS323
I have a problem, having the SD adopted as internal storage, the device stays black screen. Removing everything works well. Does anyone know if there is a solution for this? Since I have had to format SD several times in order to use it.
I'm using adoptable storage and everything worked without problems since I followed the instructions of migration from CM, I'm using TWRP 3.0.3 also
I discovered an annoying bug: when you uses the camera with the flash on the app stops working
Also the build corresponding to February 23 makes my device bootloop
Hello there, I am the proud owner of a LG-D320n L70. I currently use the 14.1.20161225-NIGHTLY-w5 of CM, that as all older versions does not support NFC, i am perfectly happy with this version, but i am itching to try this new gorgeous fork/OS upgrade. After some googling i found out that only my hardware version (D320n) supports NFC and only one relevant post about fixing the NFC back in the old days of lolipop https://plus.google.com/+JimmyCooperTV/posts/DFEypPbGP9U
Is the LineageOS build based on a NFC-less version of L70 (w5,optimus i don't know the official name :p )? Will there be possible for a rom that addresses the NFC issue, or is it unachievable?
Thanks for your time reading my post :)
I don't have L70 version with NFC. I try make same as in G3s (nfc fully works), but as I know it not work...
The new build 2017-03-17 is more fluid.
Bug:
Sometimes the screen rotation fails in YouTube App. However, it works again after restarting the device.
Device model does not appear
Device: LG L70 D325f8
Hello again :) ,i have good idea for all,this rom is best,but is really slow,that idea is this:Lineageos rom w5-aroma installer
aroma installer-in the rom i don t need wheather and many apps,and i need in thiw rom to be fast
i have 50% free ram but its slow,i have only messenger,facebook,smart launcher pro and many apps for dayli use and it is slow.
again...this rom is very good,but many slow....we need this rom to be faster......sorry about my english.have good day :)
I think I messed up the flashing process for my MS323. You see, I had CM 13 and wanted to flash the newer Lineage 14.1 OS. So, I updated my TWRP to 3.0.3 and added all the necessary files. Then, booting into TWRP, I flashed the Lineage ROM only to find myself stuck in a "soft-brick" being unable to boot into the OS. It only redirects me back to recovery each time I boot up my phone. So can anyone help me? Thanks.
Nevermind guys, I fixed it by doing a full wipe and then using ADB sideload to flash instead. Took out the battery and turned it on, and viola! The boot animation finally came up! I will update on whether the boot was successful or not. Cheers!
