Root Lost Recovery Mode
jtragna
Member
Hi, When i try to go into ClockWork Recovery Mode it just brings me to a black screen. I'm running Backside ROM, and i tried the Second half of this tutorial to bring my phone back to the original state: How to Return LG Optimus V to Stock - LG Cell Phones Blog I put in the code/commands in the second part and disregarding the top part (Thought they were diffrent methods....Whoops!) and didnt flash GAPPS to BackSide yet....Whoops agian....anyway to get Recovery Mode back? Thanks!
What screen and drivers do you have, Novatek or Hitachi? What ClockWorkMod recovery version did you use? How did you install it?
Note: If you have a newer Optimus V purchased after November 2011 with 2.2.2 OS originally installed then you have the Hitachi screen and drivers for sure.
If you installed the recovery from ROM Manager that recovery version is incompatible with the Hitachi screen and drivers.
Go to the All Things Root Guide sticky and download the BobZohme modified CWMod recovery (VM670NH_recovery.img).
Using a file manager move it from the Download folder to the root of the sd card making sure that it has a .img on the end.
For ease of install rename it recovery.img (this is important).
Go to the Play Store and download a terminal emulator. Open it up and type in: su (then hit the enter key)
Superuser will prompt you to allow or deny. Allow, then go back to the menu and select toggle soft keyboard.
Now type in this:
flash_image recovery /sdcard/recovery.img (hit the enter key)
You should now get a stream of almost identical looking code. When done there should be a # at the end.
If you did not get any errors then type in this:
reboot recovery (hit the enter key)
It will now boot into your recovery menu.
Note: If you got any errors in the code then do not type in the last line of the code. Recheck what you typed in and try again. The code is case sensitive, you must make sure everything is typed in exactly as ^ making sure the spaces are in the proper place as well.
(hit the enter key) do not type this in, just hit the enter key.
I fixed it myself...i should have taken down the thread, sorry, but I installed Xionia Recovery insted, and I have to say, I like it WAY better! Thanks for your help though haha
The BobZome recovery will work better for a CM-7 and CM-9 ROM.
The Xionia will work for all of the Froyo ROM's, but when it comes to the Cm-7 and 9 ROM's you will have to wipe and format everything necessary 3 times to insure you don't leave any residual data behind to corrupt the ROM.
It's really not about what looks the best, it's about what works the best. I really like the way the Xionia looks, but was forced to go to the BobZohme after getting to many force closure's slowly creeping up when trying to use the CM-7 ROM's.
I now use the Touch Screen recovery. It does just as good a job as the BobZohme but it will allow me to use one hand (thumb) to do everything. This allows me to use the other hand to work the mouse.
