Root low battery when charged
what exaclty does titanium backup? is there an app that will backup my apps and restore them in the order i had them shortcuted onto my homescreen?
I don't use titanium backup. Perhaps someone who knows it better can respond.
im on eclair now. i want froyo but is it stable?
Stable, yes. Perfect, no.
You'll need to flash the DK28 modem with Odin. Find the ROM you want HERE and go from there. :)
I'm not running "stock" froyo so I can't comment per say. Everything that I use is working fine and correctly though.
wut are you running? have you heard of this problem, the battery percent drops around %30 within minutes for no reason. then when i plug charger in it seems to take forever to start raising the %.
Quantum 2.1.0, thinking about trying Bonsai though.
Negative, have not heard of that problem. Try fully charging the battery, wiping the battery stats through clockwork and fully draining it to see if that fixes it. If not, get Sprint to exchange the battery.
sprint already ordered me another epic. im just using this one as my guni pig for now. it was just at %19 then i pulled battery and charger then put them back in powered on phone and its at %60
i did this
Alternate Instructions: Update Android 2.2 Froyo for Epic 4G
Intended for those going from any other version of Android to the latest firmware.
  1. Download the required .tar file
  2. Download Odin
  3. Open up Odin and put [COLOR=#212121 ! important][FONT=inherit ! important][COLOR=#212121 ! important][FONT=inherit ! important]your [/FONT][COLOR=#212121 ! important][FONT=inherit ! important]phone[/FONT][/COLOR][/FONT][/COLOR][/COLOR] into “download mode”
    • Turn off your phone, wait until the lights turn off
    • Hold “1″ on the keyboard while powering up
  4. Plug your device in
  5. Place the .tar file in the PDA slot
  6. Start flashing
  7. Congratulations! You now have An
and then odin said
<ID:0/006> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> MD5 hash value is invalid
<OSM> SPH-D700-DK28-8Gb-REL.tar.md5 is invalid.
<OSM> End...
i dont know what IIRC is but i renamed the file and then odin says
<ID:0/006> Odin v.3 engine (ID:6)..
<ID:0/006> File analysis..
<ID:0/006> SetupConnection..
how long should it say this cuz its not doing anything else
Yes, DI07 is stock.
If you reroot, you can find the DK28 modem, flash it through odin then use clockwork to install a DK28 ROM.
so do i need to update to 2.2 before i load custom rom or just drop the rom file on sd card and go into recover and click load update or whatever?
