scottborasjr
Member
system/bin/sh: su not found
device not found after typing su
I put super su on the phone but still doesn't find the device.
rebooted phone and tried again and didn't work.
I know I'm missing something stupid but I've been reading for almost all of my free time for the last 36 hours and can't figure it out.
Yeah I typed it in 10 ways from sunday. I haven't had any luck flashing anything yet without root or TWRP working. I'm assuming there is a file that I can flash via fastboot? Thanks again for the time, I know this is exactly how you want to spend your Saturday night.
 , so it is all good
, so it is all good
That's the biggest problem, I can't get a recovery to stick. TWRP either from Goo Manager or from installing via fastboot isn't working.
2.3.1 it says something about the it being outdated for the core, I think I will have to factory reset and start over. I unfortunately have to go run a couple of errands for the wife so I won't be on here for the next half hour to 45 minutes. I truly appreciate the effort and will try more when I return. Other wise I will probably be bothering you again in the next few days. I just can't stand not being able to do what I want with this device and really not used to it since normally I root and take care of things within the first 6 months of release. Thanks again.
When I download that from chapter 3 it says it's a disk image file and when I'm in the bootloader I can't find it.
do I need to rename the file as PCIjmg file, or whatever that code is, sorry trying to get the baby to bed. I followed the directions with that file from chapter three and it won't do anything.
1.go to openrecovery-twrp-2.4.1.0-jewel.img to download the file.
2.move the file into the android folder you created earlier when you unlocked your bootloader.
3.on your phone you should be in the bootloader menu screen, select the fastboot option. if you are not in the bootloader menu then power off the phone and then press and hold power+vol down.
4.on your computer press and hold shift while right clicking the android folder.
5.select open command window here option (windows 7)
6.enter command:
Code:
fastboot flash recovery openrecovery-twrp-2.4.1.0-jewel.img
Could you boot your phone to Hboot and post up the information you see on the screen?
Once we have that info we'll be able to help you get sorted out.
Jewel Oct ship s-on rl
Hboot: 2.09.0000
Radio: 1.13.11.0830
SpenDS-31.1.0.45.0815
eMMC-boot
Oct 18 2012. 15:46:20
just reporting in, as of right now bootlodder is unlocked!!..i will continue a bit later.
thanks for the warm welcome!
