Congrats and welcome to the dark side!!!!!!
Thanks. Now to restore all the settings that were lost during the unlocking and NOT covered by Helium Backup (all my sounds, wallpaper, alarms, etc...), then look into making a nandroid backup.
So, what new phone are you getting?
I think most people use Titanium Backup, I like MyBackup Root.
I'm privy to Viper roms myself, but there are a few good AOSP roms like Beanstalk.
If you update your phone to 4.3 using the method Cap'n Throwback provides here: http://androidforums.com/evo-4g-lte...-sense-5-android-4-3-update-4-13-651-1-a.html you can run the latest Viper 4.0 or the newer KitKat AOSP roms.![]()
so ive been using beanstalk since ive been rooted, i like but i think i need to update to the latest version. im just not sure how this is done.
im running beanstalk version version 4.3.05.
To use either the new Viper4G or Beanstalk using the new partition layout, you must follow Cap'n Throwback's instructions (linked at both roms, so it's true) -
[ROM][FIRMWARE][RECOVERY][STOCK] Sense 5, Android 4.3 Final Update - 4.13.651.4 - xda-developers
Note he says going with the RUU for this is best.
The Beanstalk thread lets you get to 4.4.249 using the old partition format you have now, or up to 4.4.285 with the new -
[ROM][KitKat][4.4.2][Unofficial]BeanStalk Build 4.4.285 NEW_FORMAT- 4.4.2 [Jewel] - xda-developers
Both are 4.4.2, so you can try the slightly older one hassle free if you prefer.
Does this help?
i took the hassle free route, but i was hoping the update would fix my bluetooth not working. and no luck
Sorry.
Is it Beanstalk or hardware?
If you have an earlier Sense nandroid from before you started Beanstalk, that would say for sure.
I think, I do have it. What do I do flash it using twrp to return my phone back how it was and Test Bluetooth conectabilty.
Another issue I'm having. Is I'm having randomly losing my network connection. I can get it to reconnect if I reboot.
My phone says its in " digital romiming " I don't know that means
I can't reboot right now but basically -
Go to TWRP, Advanced (I believe) and look through the options - you'll find one to mount internal storage for usb access.
I don't know what effect running the test program will have but it's worth a shot.
Remember to unmount (eject) on the pc side and stop the usb access in TWRP when done before removing cable or rebooting.
Thanks as always Early
When I try to mount, it is not popping up on the PC side (Windows 7). TWRP 2.6.3
(Updated to Android 4.3 in Feb.)
It might all be related, so let's check both your current software and settings first.
Very important question - do you have s-off?
If not, begin by getting a copy of your nandroid that you want to restore over to your PC. You'll need to extract the boot.img file - and I need to know if you're on Windows, Mac or Linux to advise on that.
TWRP, Backup, make a nandroid of what you have, use the default settings for boot, system and data.
Back to main TWRP screen, Restore, choose the old Sense nandroid. If s-on, don't bother with boot, otherwise, restore boot, system and data.
Back to main screen, Wipe. Choose to wipe cache and Dalvik and nothing else.
Back to main screen, Reboot. If you're s-off, just reboot system.
If s-on, choose to reboot to bootloader. From there get to FASTBOOT mode. Either your phone will go there and you'll see it listed at the top, or it be in the menu list and you have to go there.
Connect to usb if not already.
Move or copy the boot.img file to where your fastboot is. If you used our Mini SDK and followed our instructions when you first rooted, that will be under the sdk-tools folder.
Open command window in that folder. Then enter in command window -
fastboot flash boot boot.img
When done with success, enter -
fastboot reboot
And test out your phone.
)i am S-OFF. turns out i dont have a nandroid before beanstalk (or i just cant find it)
I tried to run this one but i got as far a the HTC screen i waited about 10 minutes and it didnt bootup.i went back to recovery and restored back to where was.Boy, I know that story.
Ok, all is not lost.
Check our sticky thread, I bet we still have the link for the earlier (non-4.3) stock Jellybean rom.
See if you can still download it.
I bet you can.
Make a nandroid backup, grab that and install it.
Doesn't matter about all your apps etc etc etc like a nandroid restore - we don't care about that right now, just testing your hardware with stock HTC software.
Dang, it's always something.
Let me think...
Ok - no Aroma installer? It just went right to installing? In such a case -
TWRP, Wipe - boot, system, data, cache, Dalvik - install old Sense rom.
install failed
Yeah, I forgot about that - mine worked pre-4.3 when /sdcard really was it's own filesystem, not shared with /data.![]()
Sorry to bug again.
So referring back to my prior post. You think there is anything that can be gleaned with the potential TWRP back up files (nandroid)? I'm not sure about where to start on restoring from them, converting them, or searching/extracting files from their image.
