Help Max gb MicroSD in HTC Desire HD?
32gb, I don't think there's any bigger at the moment.
Should be able to take more when they produce them though.
I ordered this one, mainly because it is a Class 6 card:
Lexar 16GB MicroSDHC Card - with Reader | Ebuyer.com
It's the best card capacity/class for the money I could find (all of the 32GB cards seem to be Class 2/4). I hope the Class 6 nature of the card will speed up my transfer rates via USB, which on my Windows 7 VAIO seem to float at around 3mb/s on the stock Class 2 card, in theory the Lexar should pump that up to at least 6mb/s, especially helpful when playing SD/HD DIVX from the SD using Vplayer.
Will report back after my purchase.
Not saying that everything you buy on ebay is going to be fake, I actually buy a lot of things there.
Though expecting to get a 32GB SD card for ~
Indeed, especially as it is so so easy to hex edit the cards.. pick a number, any number. If you do get a 32GB card, fill it with 32GB of media - Windows/Android will (mis)report whatever number the 'hacker' wants.
My guess is they are in fact C2/C4 16GB cards. The moment you go over 16GB, you'll get a nice fat file write error.
Ok.
But if there will be 64gb cards(some day there will be 64gb cards?), would HTC support it? No limitations for HTC???
Then HTC have replay me, just a 1 or 2 hour, and they was answeer me :-)
Very very impressive :-)
I asked HTC about HTC Desire HD(and other HTC) will support microSDXC, or more then 32Gb storage.
If not, would they support microSDXC / more then 32Gb storage if HTC make fimware update later.
HTC`s answeer
Thank you for your email regarding the HTC Desire HD. We can certainly understand your concerns and wanting to use the device to the fullest. Currently, the specifications of the Desire SD do not have compatibility for SDXC. The phone is only currently compatible with SDHC microSD cards to a capacity of 32GB. We, unfortunately, do have any devices that have higher capactiy.
Again I am very impressive about fast answeer in a week end :-)
Considering they have said Desire SD, I doubt emails get verified before they get sent haha.
Theres no real need to switch just yet anyway as most people don't load there phones with music and record like mad either...When the time comes, you can be sure HTC will make the switch :)
