nicklovell23
Member
beta 4 uploading now.....
How do I make the icon bigger?
I had to change my lcd density to 320 under settings/interface/lcd density. Just follow directions listed there.
Thanks, it work...
Beta 5 didn't load for me. It fc'd the aosp keyboard. So I couldn't even logon to anything. Anyone else having problems with #5?
& now I can't get into recovery mode. Thanks
What recovery you use if it's twrp thats your issue also must do clean install factory reset wipe caches format system manually.
OK just to clarify please go to the slimroms.net and read the home page before flashing.
& I did wipe everything before I flashed beta 5, a complete data wipe (except sd card).Yes, I am using twrp. Never had any problems before& I did wipe everything before I flashed beta 5, a complete data wipe (except sd card).
Beta 4 was working just fine. Finally got into recovery. reloaded beta 5 with pa gapps. Now it's all back working just fine.
I did notice on the home page about flashing the rom & gapps. I flashed them both together. Now, if I read it right, are they saying to actually flash them separately?
I had probs becuz of twrp but like nick said its twrp. I then switched to Cwm touch and wiped everything manually and it fixed the issue ur having
Has anyone paired their phone to their car? When I spoke to my gf, she said that she could barely hear a word and that there was a lot of garbled sounds in the background. I restored my rom back to Carbon 4.2.2 and she said that I sounded crystal clear.
