How do you center the clock, change battery icon, led change color like other aosp rom's? Really want to use this rom but want to be able to change this minor things. Thanks in advance.
Clock:
System Settings - Interface - Status Bar - Clock and Date
Battery icon:
System Settings - Interface - Status Bar - Battery Icon and Bar Style
LED:
System Settings - Display - Battery Light (used for low, medium and fully charged)
System Settings - Display - Pulse Notification Light (used for custom LED notifications for general and specific notifications.
Nick, are you doing this latest stable build or waiting for their 4.4 releases?
I have Slim-Beam 4.3 build 2 installed, and the dpi thing is driving me nuts.
I don't have a "developers options" in settings; but I do have
Advanced Options->Superuser->(settings button)->Settings->Superuser Access->Apps and ADB set.
I go to run SuperSU#, it informs me the SU Binary needs to be updated, I Continue->Normal and it fails.
Since I don't seem to have root, I can't change the dpi.
Suggestions?
This is what i'm running - doh - I'm on the MetroPCS forum. I'm on Sprint.
Should it matter for my issue?
Discovered the 7 taps to enable Dev Options shortly after posting the above.
It didn't change anything.
So, currently:
1. DevOptions->Root Access shows "apps and ADB"
2. I've rebooted into TWRP and have tried (either both or singular) "Advanced->Fix Permissions" and re-installing "TeamEpic-Root-from-Recovery-v5"
If I re-install "teamepic-root-from-recovery", on boot into the phone, I'll see a google message about "updating apps" before getting to my lock screen.
I re-enter Settings and verify "Apps and ADB" is still set, then launch SuperSU and the "Update->Normal" path contiues to result in "Installation Failed!" message.
And I give you SlimKat 4.4.1
Please make a backup, wipe dalvik,cache partition,format, and format system manually. Enable root like on 4.3 builds.
Rom Dev-Host - Slim-d2mtr-4.4.1.beta.1.2-UNOFFICIAL-20131208-0033.zip - The Ultimate Free File Hosting / File Sharing Service
Gapps Downloads - Addons4.4
Nice rom, very fast and smooth. Thanks for supporting our device, nick.
How can I change the DPI settings back to stock?
Its beta right now so have to edit the build.prop density line to 320
I have run into several problems when trying to flash this. When using CWN Touch as my recovery it will flash and the ROM will boot but all of my network settings (IMEI, MEID, phone number etc...) are gone.
When trying to flash using TWRP as the recovery it will not successfully flash. It will get to the part of "set_metadata_recursive" and it fails with the error of "some changes failed". I am going to assume that this is normal sine CM 11 cannot be flashed with TWRP as well without this type of error.
I simply restore the fresh backup of the ROM I was running so none of this is a big deal but it is strange that I cannot flash it using CWM Touch recovery yet it appears that some people have had some success flashing it.
Oh....and yes...I was factory resetting and then manually wiping and formatting as well.
