Root [MetroPCS/CDMA] [ROM][OFFICIAL] CyanogenMod 11 Nightly Builds for d2mtr
ClockworkMod ROM Manager - ROMs)
Can't download this at work through goo. If anyone has a mirror, let me know.
Cool will give it a shot are you just running the nightly build?
Edit I have a backup of the other build all I have to do Is just updated right instead of doing a new install
I did a clean install because I didn't have a backup but I think dirty flash will work too. Just got to flash 4.2 gapps too.
Yep data works. And ICCID still says unknown. I have developer option cause i know how to get it to show up. Go to settings about phone scroll all the way down and tap build number three times, it should say you are now a developer.
Ok cool thanks good info. :)
Edit: I tapped it three times and it said "you are four steps away from being a developer" 4 taps later and it's official. I'm a developer. Lol
No big issues here I noticed it's missing the weather option is missing also a little flicker on gallery and the videos show up in purple will let the cm team know about this excited to play with 4.2.1:D
I didn't have any force close issues either. Maybe try a clean install.
I haven't seen an inverted 4.2 yet but the modders are probably working on it as we speak.
I went back to blackbean the files setup with cm10.1 is too chaotic. Too many duplicates files and folders. Yikes.
The app and built in tether are dead
I've always used WiFi tether can't seem to get it to work on cm 10.1
Seems when I looked it up most apps to wifi tether wont work on 4.2.1...
And since I know a mod will come talk to me again... im not talking about how to tether... and to be truthful metro knows I am and im covered under my plan for hotspot use.
Works fine thanks.
Quick question, I've also used gapps jb 20121212 signed version as well. There isn't the pinch zoom in Gmail and Photosphere. Is it too buggy or is there a working gapps out there I can use?
For Gmail, go to settings and check the box that says "shrink to fit, allow zooming" and then it works.
I am using the built in app. When you updated to 10.1 did you do a factory/data reset wipe, Dalvick cache, and the cache. I had to do that so it would stop the force closes and get other things working again.
What's your user agent set too... My computer sees I'm connected but not able to provide internet 4.2.1 needs a new agent
Chrome is the easiest for me. I could never get IE to work. Firefox works but seem to require more than one user agent switcher to work.
In Chrome just go to apps store and search ua switcher. Install it and set it to android. Done deal. (this is all from desktop)
Lil I'm triple booting lol and I got it... I had to load the WiFi driver binary and walla doesn't show speed or data used but its working. Lol my good old friend Google showed me how to do it on a nexus so same concept applied to my sammy
Hey Guys, I had installed the stable cm10, but sometimes poeple call me and i don't get calls also if they text me sometimes I don't get their SMS. So, anyone else has try the stable with this problems?... the screen sometimes don't wanna wake up if I press the button from the botton and the proximity sensor has issues when I am calling it turn off my screen I cannot see a thing... I would appreciate if some try another rom without these issues...:)
Yeah man, I'm also getting force closes. Basically, after I flash 10.1. Says
"Unfortunately, the process
com.google.process.gapps has stopped"
I'm also flash the latest build of CM 10.1 (1227)
What GApps did you flash? I'm on the latest nightly and haven't had any problems.
Could someone help me out? I just flashed the latest build of CM 10.1 (1227) and when I go to boot up , my phone force closes and says
Setup Wizard has stopped and that com.google.process stopped as well. I went back into recovery and wiped the cache and dalvik, tried a few installs and nada. I'm also using CWM to flash.
