knightshado
Member
Unknown iccid
Unknown iccid
The flickering in the dec 22 build is so bad it's scary. I thought my display was going out.
I can't find the development option in settings either and I'm really not liking how they're moving our internal folders. It works for cm file manager. But what about when we go to restore our previous rom and there's nothing left to restore to because they moved it.![]()
I thought you are supposed to use Rom manager for CM and goo manager for aokp/ baked bean
I really hope that everyone with these issues is correctly reporting them otherwise they will take longer to get fixed. Easiest way to get issues fixed is following the directions for CM.
How do we report. I missed the directions for that too. It doesn't seem like the op is even reading this.
He reads everything u guys need to relax that's y there nightly's there's alot of bugs in all the nightly's for other Carrier's, we are not the only one....
Edit: try registering on cyanogen. com and you can report all bugs...
Hi everyone, I recently installed the Cyanogenmod nightly (cm-10.1-20121222-NIGHTLY-d2mtr.zip) with CWM and everything worked well. Then I wanted to add Gapps , but now I am getting a pop up "Unfortunately, Setup Wizard has stopped." I can't use settings, apps, etc. Is there a way to fix this?
Is data still out ?
Is data still out ?
I have a question, when you want to restore/go back to the original stock rom do you need to do a factory reset and wipe everything like if you are going to install a new rom or just restore the rom back?
