Tried using triangle away to reset my counter,but it came up saying "magic header not found incompatible device ?"I don't know what that means,however it work just fine on my galaxy tab 2 7.0
What's your count at? Mines at 3. I rooted once and flashed 6 custom roms, HA! In your face Samsung.
Did you set up wallet initially? If so did you reset it before flashing a ROM?
They could be saying in your face if the nfc element is destroyed because of flashing and not setting up wallet right.
But i guess it wouldn't matter if you don't use it.
I'm thinking he means he flashed custom cm10 6 times....
can someone pleaseeeeee flash tiede's unroot stock file to confirm it's working.. I rooted my phone but now need to take it in to metropcs store cause I'm having problems connecting to 4g (i only can connect to 3g) and yes I'm in 4g area will appreciate it much!!
thanks
why not just flash it, we wouldn't post nothing to do harm to anyone's phone.![]()
lol i know but tiede gave a warning and i take it serious..
have you deleted any apps? Or you just need to be unrooted with stock kernel?
nope haven't deleted any apps. but i did root.. so yeah i need to unroot before taking it in
Just flash the stock tar nuttmeg linked you to in Odin to get the stock recovery back. Then go to the supersu app in your app drawer go to settings and tap full unroot. It will remove su from xbin and also remove the supersu app, thus unrooting your device![]()
This is what I get when I try to use triangle away when I try to reset my counter
Oh, I thought you got it while trying to theme the phone in Dakra's uot kitchen
It wasnt built for metro version, you can contact the Dev who created it at XDA and see if he can add it to the list.
I contacted chain fire already, not sure when or if he will get around to it. I hope he does. I don't think you can reset the counter with a jig on this phone, only boot into download mode with one. At least from what I've been reading.
