mikekelso421
This is all the useful info i have as of right now for anyone with an HTC Evo flashed to metro pcs.I am willing to add or edit any info i have provided to make things EASIER to find for this specific phone one METRO PCS.Thanks for your suggestions in advance and i hope this info with help!
To program data to Metro pcs (must be using a SENSE rom) clickhere
For ROMS click here (rom's are out-of-box metro-ready:CM7 & Sense 2.0)
For all the zip's your gonna need,download from these 2 links metrOFF & MetroPCS MMS & Web Script
The .zip titled"MetroPCS Evo AOSP MMS & Web Script v4" you can use to fix MMS on ANY AOSP and most MIUI ROM's.Just flash it AFTER you flash the ROM of your choice and it should fix your MMS.(MAY NEED TO REBOOT TWICE)There is ALSO a similar WEB/MMS fix for SENSE ROM's as well in the same link above.
Programing Data/MMS guide WITH PICTURES here
Here is the link to some fully compatible Sense ROM's that works well with the METRO-FLASHED EVO.
Azrael's Sense ROM + 3.70 OTA sense 2.2 script
Smooth N Sexy Sense (SNS) + 3.70 OTA sense 2.2 script
Synergy RC1 or RC2 + MetrOFF GB.zip Havent tested any other release of synergy to confirm it works.
MY Out-Of-Box MMS -READY CM7.1 ROM (mms working on first flash)
mikekelso421's MetrogenMod 7.1
ANY AOSP ROM WILL HAVE WORKING MMS IF YOU FLASH THE AOSP .ZIP FROM HERE.
I will add more to this thread as i find more useful things to share!
AND NO MATTER WHAT ROM YOU FLASH,YOU WILL NEVER LOSE TALK AND TEXT!!!!!! IT WILL ONLY EFFECT YOUR MMS AND WEB!!
!HOW TO UPDATE YOUR PRL FOR 3G DATA!
YOU MUST CONNECT YOUR PHONE TO THE COMPUTER.AT THE "MAIN" TAB,HIT CONNECT BEFORE ANY OF THIS WILL WORK.ONCE CONNECTED,START STEP 1.
STEP 1:Find the latest and greatest PRL as of now is 3025.
STEP 2: Download CDMA Workshop if you dont already have it.before opening the program,disable your anti-virus (AV causes CDMA not to work)
STEP 3: once opened,go to the tab "OTHER",on the right side you will see PRL and 2 buttons READ and WRITE.click write and a dialog box will pop up to select your PRL,navigate to where you have it downloaded to.
STEP 4:select your PRL and then click open,once it says successfully written,reboot phone and NOW YOU HAVE THE LATEST PRL FOR BLAZING SPEED UPGRADES!!
Before PRL update
After PRL update
[HD VIDEO]HOW TO UPDATE YOUR PRL-HTC EVO 4G ON METROPCS
HOW TO-Evo On MetroPCS PRL Update - YouTube
Before PRL update
After PRL update
now hopefully i can add MORE to it.lol hard to find stuff on this topic.
i have to say your wrong...the 4G statement was dead on acurate..but as far as 3G goes,no go..believe me,ive seen this topic alot on the forums and i never got anything other than you cant do it (forgot why they said you cant but..unfortunatly for us metro users,no 3G for us.... but i use wifi 95% of the time anyways!
