@Bard Hey Bard. I would like to thank you so much for you ROM. It is just like stock but what I am concerned about is if there is away around the metropcs hotspot tethering block. I know that it is something within the code but I haven't delve deep In that mess. Furthermore, I did get through the hotspot code but my phone was flashed to CarbonROM but didn't like it because of the bugs and signal it gave off. So do you think you can see how to by pass this mess?
that launcher that ships with this ROM doesn't have notification count. (displays the number of unread items on the icon). But i notice that there are some launchers (especially the one shipped with kit kat mini ROM) that displays notification. Is it possible to install the LG home from kit kat rom on this? will there be any problems?
I installed the update mentioned in #145 and it went fine. Surprise is that the new launcher now has partial support for notification count that I was looking for.
it now displays no of missed calls, texts and whatsapp messages. But the email does not display the no of unread items. Is there a way to fix this?
* Modified Build.prop little bit
- NFC turned off default
- Default Brightness reduced to 30%
08/21/2014 - Live V.1
* Aroma installer added
* TR, Recovery apps removed (the device is still rooted and recover installed)
* Gallery added back
* I used most recent Google Search (Google Now) and Google Keyboard but it still says you need to update them. Just click okay and update.
08/15/2014
* Beta V.1 uploaded
* Initial upload to the public
I wiped everything except sdcard using advanced wipe from twrp and rom installed great but now i dont see app to boot into recovery anymore.do i have to reinstall recovery again?Thanks in advance for your help.
