pressy4pie
Ok, yall havent got much love for this little phone but ive got something coming together. I am not really sure why i am releasing this because as far as i can tell it is completely useless for the most part. But lets see if any of you guys can get me ideas on stuff that is or is not working.
This is absolutely not a "how to build" guide. If you can't figure out how to build the source tree, or don't have the ability to build it or wtfe don't bother. I expect you to be able to follow basic instructions to get this building and going.
First of all here is my special sauce:
Kernel Tree
Device Tree
ok so there's that. Also you are going to need a system dump. Doesn't matter which one i don't think. Mine was 12b If i remember correctly. If you are tying to build my sources, you are going to have to do a couple things before it will complete. First, you need to go into <croot>/hardware/qcom/media-caf and add msm8930 to the filter. then your going to want to get a prebuilt kernel and drop it into the device tree <croot>/device/lge/f6mt/kernel
after you have that all set up, go ahead and lunch f6mt. Then since our device doesnt have appropriate headers, build hwcomposer separately.
after all that you can finally brunch f6mt and it /should/ spit out a zip in whatever rom your using. im in Carbon right now, so you might have to change carbon.mk to cm.mk and change the carbon stuffs to cm. I don't know why i chose carbon first rather than cm im sorry i just had the tree already synced and i didnt want to sync cm because i have extremely slow internet.
Go ahead and flash that however you want. Im using stock partition layout, but i guess it would work with my sdcard hack thing if you went and changed some dirs in the root dir.
ok im done rambling i guess. for those of you who didnt quite catch that, ill have a testing zip up on my site once this build finishes.
Hop onto irc if you think you can help me out.
Kernel Tree
Device Tree
