there are no firewalls at his house except normal router firewalls.Yea, so...download this:
http://csmgdl.lgmobile.com/swdata/WDLSW/LGMS659/AMTPTN/V10b_02/MS65910b_02.kdz
Flash the kdz just like how you would on the motion.
Thanks for posting the kdz files. This is my first experience using kdz files. Searching the internet, I found this link you authored for the LG motion.
http://androidforums.com/motion-4g-all-things-root/610609-guide-unbrick-unroot-lg-motion-4g-kdz.html
On step 10 it says "choose CDMA". Is that correct for a T-Mobile F3? Thanks
Yep. Um don't use the motion files to unbrick F3 though.
All of these csmgdl.lgmobile.com links show as access denied for me!!! I just did factory rest and the phone is in soft brick!!
Actually this one works... I hope it's the right one for T-mobile F3
Man I feel lucky. Got the file from the link above, followed this guide:
http://forum.xda-developers.com/showthread.php?t=2191698
and all went well. I am back to stock, but am up and running.
HOW I BRICKED: I had a rooted, LTE 2nd Init Recovery ----a software. I deleted a bunch of system apps (with Titanium Backup; had backups if I got into trouble.) I decided I wanted the update, so I did factory reset from the stock recovery .. and it bricked my phone. I would boot up, see the status bar, the phone would buz for SMS, phone calls, there was nothing on the screen under the status bar. I could not make anything happen from the notification dropdown. Still have access to the stock and the CWM 2nd init recovery.)
The flashing put be mack to ---a , bare stock, unrooted... and I just updated to the ----b software.
Time to install the apps I want, but I guess I will keep the modifications to a minimum.
hi guys, im new around here, got a tmo f3 stuck on lg logo. couldn't do any thing about it except get into emergency(download) mode. lg support tool couldn't help, after reading this thread I might try to use kdz to flash tmo firmware p65910a, might solve problem. the thing I couldn't access any of the links to download those files. wether access is denied or page not found . please any help would be appreciated.
