android's kernel will not detect adhoc connections natively.. you will have to broadcast your wifi in infrastructure mode only..i.e. connectify, mhotspot or virtual router
A exact screen protector is not available yet but you can make the shopkeeper to cut it any other screen protector according to your screen size and put it.
Or instead of using screen protector just laminate you mobile.
It costed me Rs 120 laminate.
If you laminate your handset then no need if sp
if you want to just use screen protector then it will cost you Rs50 to Rs.150.
But I recommend you to laminate.
You can get a variety of covers from letsbuy.com
No.
Lamination doesn't block any of open spaces which are meant to release the heat (although we don't have any)
And if it blocks e.g. speaker holes at the back,Mic then u should get it cut.
We have to see and match the exact dimensions of a70 with covers available and then buy.
We have dimensions mentioned in gsmarena but how to see covers dimensions in letsbuy
Do u want to use net on pc or phone???I assume u want to use it on pc.
Connect the phone n don't mount sd card,
Go to Settings->Wireless n networks->Tethering & portable hotspot
Now check mark USB tethering.
Now u can access internet on pc.
EDIT:
Sorry I didn't read it properly,u want to use pc's net on phone.I don't know of that but will update u if I find anything.
does anyone know which browser supports full HTML5?
I tried uc browser 8, 7.8 it doesn't support it.
just visit this site YouTube - Broadcast Yourself.
u will see three bars at the bottom.
the green colour represents it supports.
There are 3 bars:1)video tag 2)h264 3)Webm.
Our stock browser shows only green colour for video tag.
Can anyone find the browser supports it fully.
If not fully then at least two should be supported.
HTML5 will help us play videos on any site without flash player.
Also we can play games on ibibo,facebook AFAIK.
I dont want just a support while i need Full support.
Just visit the link i gave and see how many bars turn green.
Try it with chrome as well as on skyfire.
