Root MikFroyo 4.4 vs. Azrael 3.1
Roymus
I notice both of these ROMs have been getting a lot of activity on this forum over the past weeks. I've recently flashed these two ROMs and gave them a workout for a week or so...nothing scientific, just normal usage. Here are my general impressions...again, I'm not a scientific reviewer, so YMMV.
Functionality: Both of these ROMs are based on HTC Sense, although they've both been optimized and significantly speeded up. Both come with the Sprint Hotspot hack allowing free use of the Sprint hotspot feature (note this only works with 3G though). Both also come with the Wireless Tether app as well, which supports 4G and 3G in ad-hoc mode. MikFroyo also comes with a few other goodies: notification widgets to turn on/off network functions, Hulu, and a few others. I actually liked the fact that Azrael comes with a version of Titanium Backup in the ROM...this makes it easier to restore your apps immediately after flashing. Azrael also comes with apps2sd (free version), which I recommend for moving your apps to your SD card. Azrael's ROM allows me to free up over 220mb of internal phone memory, which is more than MikFroyo (although not by much, they're comparable but every mb counts). I find that having that much free memory has probably the biggest impact on my Evo's stability...thanks, Azrael!
Speed: MikFroyo gets a lot of props for having the fastest custom Sense ROM available. My informal tests show that while Mik is definitely faster than stock, Azrael performs better (at least for me). My Evo is hw version 0003, and I have netarchy's 4.3.2 SBC non-havs kernel. With Azrael, scrolling is noticeably faster and lag is virtually non-existent, while with Mik my phone is still laggy when scrolling (although transitions are quite snappy). Azrael's ROM gives me significantly higher quadrant scores...typically in the high 1300's and even the low 1400's, while Mik's are in the high 1200's and low 1300's. I know that quadrant scores aren't the be-all and end-all, but they continue to be a good predictor of performance for me...and for me, Azrael is faster. (Note I have my Evo overclocked to 1190mHz for both ROMs).
Battery life: I think this is more of a function of the kernel you are running rather than the ROM. Having said that, running netarchy's SBC kernel with Azrael, I'm finally getting the kind of battery life out of my Seidio extended battery that I paid for (and never got). I now get 12 to 16 hours with moderate to heavy use without recharging, whereas before I would get less than 8 with the extended battery. There have been a number of posts about potential problems (if you consider an exploding battery a problem), but I haven't seen any problems of this type...on the contrary, I used to have occasional problems with the battery overheating (and causing reboots) that seem to have disappeared.
Miscellaneous: I know this is a matter of personal preference, but I preferred Azrael's ROM to Mik's out of the box. The bootup transition for MikFroyo is a bit gaudy (a flashing "MikFroyo"), while Azrael just uses the standard "htc quietly brilliant) which is a more low-key. I also like the built-in transitions that Azrael provides, although I recommend using Spare Parts to speed them up...although I'm sure that custom transitions can be applied to Mik as well. I do like the fact that Mik provides the notification widgets for controlling net functions, but I'm hoping Azrael will build those (and other goodies such as Hulu) into his next version.
Overall: While both of these ROMs get the job done and perform much better than stock, I have to give the edge to Azrael. His ROM has finally made my Evo into what it should have been out of the box...smooth, fast, and lag-free, with all the functionality I need. I'm not sure why there aren't more threads dedicated to Azrael on this forum, but I'm officially a fan who's looking forward to his next version!
I love this... I wish we had more of these vs all of the ..."which rom should I use" posts
Azrael is my daily rom and has been since I rooted my evo. I've flashed Mikfroyo, Myn's, Caulkins, and a couple other sense roms and have always come back to Azrael. I think the reason you don't hear more about this rom is because it isn't heavily themed like some of the others. I kinda noticed a while back that most of the people that are flashing roms have a different sense of taste than I do. (no pun intended) I think Azrael is the sleeper hit out of all of them personally. I recommend it to anyone that wants to stay with sense.
Oh, I'm getting pretty good stock battery life with the HTC 15 kernel with sbc (I'm a risk taker) hopefully It won't blow my fingers off (sarcasm)
... I've recently flashed these two ROMs and gave them a workout for a week or so...nothing scientific, just normal usage. Here are my general impressions...again, I'm not a scientific reviewer, so YMMV.
Thanks for this great addition to the forum! :)
I'm with Roymus on the Azreal X 3.1 pick. The main feature I love is the extended battery life. 8 hours of normal/heavy use, just to get to 50% on the battery. That alone is worth it. Second is that is appears so "stocky", as I am not one to have all sorts of wild bells and whistles. I prefer snappy and responsive, which is what this ROM is.
Oh.....don't worry I didn't miss it. Flashed it last night. So far so good. No force closes, reboots....etc. Battery seems to be doing well with packaged kernel. It's tough to stick with one ROM when so many are releasing new versions. However, I keep current nandroid backups of my favorites (CM6, Ava, Azrael, Carbon Fiber...etc.) Thanks for the FYI on the new version. :D
Question for rjd728: I'm assuming you came from Azrael 3.1. Did you do a factory reset (full data wipe) and flash, or did you just do a cache+dalvik wipe and flash? I'm running 3.1 and would really like to avoid another full wipe if possible...it's such a pain to restore everything. Thanks!
