Root MikFroyo 4.6 Streaming and Radio issues
Hemlock
I've recently flashed MikFroyo 4.6 which I like, however I can't get ESPN radio to stream. It connects then just flips to the "stop" square and will not play. Having some issues streaming with other apps also. I think I have the most recent radios but I'm not sure.
Baseband: 2.15.00.11.19
PRI: 1.90_003
Do I need new radios?
Plus, where can I get themes and mods for MikFroyo? I can't seem to find many.
Themes are on his site. I have had issues with his Rome since 4.4 and keep straying away from them.
For grins though. Have you cleared the proxy settings?
OK so your radio is up to date....there is a streaming fix that may help you that sprint has suggested. go to your dialer and enter ##data# (if on a sense rom, which mik is). it will bring up a menu, select edit, enter your msl (if you dont know this download msl reader for free or call sprint...), it will take you to another menu, select the advanced tab, scroll down to the bottom and change your proxy settings from 8085 (this was mine dont know if its the same for you) to 0, and change the very bottom one from sprint.whatver.pcs.whatever to 0.0.0.0 This should help with streaming
btw...Sure you have good signal?
I gave him detail on the streaming fix...
Not sure if themes are out for 4.6 yet, it was odex i believe
Thanks for the info, I'll try to clear the proxy setting as detailed.
As for signal stregth, it is good.
I didnt mean signal as in 1x radio, i can talk on my phone, signal. I mean 3g/4g...i use speedtest.net, theres an app for that :). Just wanted to clarify. Sprint avg is 540k, i get 1.2m but i dont exactly use sprint either...
