Root Miui ICS Help?
Nathan2112
I recently flashed the latest version of Miui Ics and so far it has ran pretty good although for some reason whenever I restore any apps in titanium backup they don't restore.. they won't show up on my homescreen.. any idea of how to fix?
I am using the pro version.. I have tried to batch all of my apps and tried it with single apps and it says restoration failed.
I wish I could help more but I'm not using this Rom. Have you checked over on xda? Maybe there's Ann issue with the particular build you're on.
On a side note, I'm surprised the local miui user Rxpert hasn't chimed in. Had you seem this before on miui?
I never had this issue. However, ever since I upgraded I've lost track of most of the EVO's progress. I check xda to see what new roms are available but I don't read the pages and pages of the thread anymore.
What version of miui are you using? Miui.us or miui.android. What build are you using aka what date was it released.
Have you tried redownloading and reflashing the rom?
I never had this issue. However, ever since I upgraded I've got of lost track of most of the egos progress. I check xda to ser what new roms are available bit I don't read the pages and pages of the thread anymore.
I am using Miui.us I believe (Thats what the boot up screen says) and the latest version 2.6.15.. I have not tried reflashing the rom. When I reflash the rom should I wipe everything and flash it like normally or what? Also the first time I flashed it, I flashed dta2sd and I got stock on the white htc evo 4g boot screen so I wiped everything and flashed i t again with out dta2sd. So how do I get a2sd on this rom? Thanks.
It has superuser permissions?
Have you tried uninstalling and reinstalling TB?
Check out the last couple of pages and make sure this isnt a new error caused by the latest release.
It does have SU permissions and I have uninstalled/reinstalled tb multiple times. I checked the last couple of pages and I didnt see anything related to my problem although there is an update for the rom. Is there a way that I can keep my current setting and update the rom?
Okay I will wipe then flash the update of the rom, then see if TB works. But before I do so, is there a way I can get dta2sd working? Above, I believe I mentioned that when I try and flash it after flashing the rom, I go into a bootloop.
