Meanwhile I've updated my sig, since I'm at least going to give this one a few days to get a proper feel.
trying the SE now, wont be ablt to test speakers till tomorrow though
i find it about the same a stock miui which isnt bad for data anyway as long as your ril is happyAre you finding that wireless data speed is better on the Vorks? They are certainly much quicker than the stock Cyanogen 6.1.1 Kernel.
Oooh hang on, let me remove that.
I don't really know what Radio Interface Layer was supposed to to but it never did it. The phone running Miui and Cyanogen would have brilliant signal for 3 or 4 minutes and then lose it completely. Interestingly I found that it doeseney actually live on the radio, its a layer and lives in one of the caches, a full wipe and it was gone.
i find the battery life on coutts about the same as vokernel however i find vorkernel a lot more responsiveI've been using the Coutts kernel and find it fine, battery life is OK and I actually hammered the phone over the weekend due to lots of rail travel so was on Angry Birds a lot...battery didn't die but was down to 4% after 22hrs and had about 4hrs of Angry Birds in that time as well as the normal apps syncing every hour and a good few phone calls.
In the mood to try another kernel but don't know which to go for
what you saying? you dont have as signal problem anymore or you do?
f you do still have issues try and find the corresponding ril for your radio version and flash it (you may need to remove signature verification)
you only had this problem on emiui or on Cyanogen as well ?Your gonna have to give me that again in English. First of all I tried a RIL a while back which I think was generic and it didn't work. Then I found a RIL for my radio version .27 (or at least that's what the file name suggested), but it was still no different. I notice EddyOS is using it now and I haven't heard him report any issues!
I lose signal after say 5 mins and the only way to get it back is to reboot......every 5 mins!
yeah i know, thing is though: i notice the responsiveness in day to day use especially with the fancy desktop scrolling anims and folders. opening of certain apps etcAs I don't use my phone for a lot more than email/FB/Twitter needing to OC/UV/Whatever isn't important - I just want it to be usable. End of the day it is just a phone and the bulk of my Internet usage is still on my laptop. So long as the phone's battery lasts a day then I'm happy![]()
if so then your provider/area might not like that radio version
im on the same version as Eddy
I had a problem with miui wifi with this radio till i flashed the RIL and then all was fine
even clocked down to 854 on a battery saving profile (under 40%) it still feels quicker than coutts
I'm on Orange, and I had the same problem with both Roms. What are the benefits of a working RIL exactly? Before I go flashing radio's.
thats basically it but he said flashing the RIL didnt help so it could be the radio hes onIt's the Radio Interface Layer so basically links the radio to the software/hardware correctly I imagine. Don't know the whole ins and outs but think that's it in a nutshell
xda-developers - View Single Post - [KERNEL-2.6.37]vorkKernel-BFS/CFS-SIO-AXI-HAVS-OC/UV[17-Jan-11]Got a link, fancy trying it out. My battery saving kicks in on 20% (default)
lol none of us work with the kernels others advise
then again i dont use twitter
Does seem that way!! Just actually realised I've been using the CFS one so actually now on the BFS one as per my signature so will see how I get on
Well maybe I'll be the exception - vork xmas is working fine for me so far. Does seem to wake a bit quicker, but then I was using smartass with the DF kernels, which isn't noted for wake-up speed (but I generally like in use).lol none of us work with the kernels others advise
for what its worth, flashed Eviollet 6.1se HAVS-BFS-AXI 128. Screen off 128-245.
Battery is lasting way longer, than stock defrost 6.1 kernel. Currently OC'd to 1075mhz and has been stable and responsive all day.
Battery still on 29%, off charge this morning at 6am, 45mins music, prob about an hour and half browsing, email syncing hourly.
doing OK for me atm.
