Root Miui Problem Sorted. Opefully!
I half inched a Vodafone SIM and flashed RIL and it worked no problem for over an hour, then I was discovered but I was in a place called Gloucester by that time so he can wait for his SIM back. How he found out I don't know but I don't think its a coincidence the moon shows up right after!
I've got the stock Orange radio (05.14) and I'll flash it later just to see if its nice.
wow, this sleep is deep
took about 30 seconds to wake it up this morning, i thought it was dead cos it wouldnt power on
not sure i like this
Which kernel/settings. I'm still on eviollet. On 61% few texts an hours music & maybe 45mins browsing. Maybe try a vork for tomorrow!
smartass for all as evioullet says
using 124 axi on sleep
did a full reboot on itself earlier when sleeping, just vibrated and came back on line
going back to vork me thinks.
good ideas and im sure devs will find a sweet spot but right now i still get 24-36 hrs with vork while being used moderately and its fast for me
I've just had forced reboot with eviollet. So just flashed vork svs cfs bfq slqb 2.6. 3. 5 and omg it is so much faster! See how it goes
Had that on a few low voltage kernels too. Especially 875 but also 900 and after that even 925.
However, new rom, 925 kernel seems stable (default not eviollet)
Sorry, yeah.
On the GB one It fluctuated between 8 and 4mA for me. Very rarely at 4 tbh. But the GV kernel is always 4mA
can you tell me how you set this up please
mines reading 192 atm, cant be right or my screen off profile is borked
Literally just put widget on desktop, set to log (not apps) and refresh to 30 secs. Will log in text file you can access from app or root of sd.
I use this to compare kernels for myself. I only.have it activated for a small period and remove it when some
For me vork is fluctuating between 2-3mA (screen off, 245 MHz, data off, 2G, very good signal), which is about equal to the best I've had with other kernels.
The only times I've ever had reboots were once when using a Sense HAVS kernel (which may have been app related) and once when running quadrant at 1190 MHz (which is anyway asking for trouble). Guess that so far at least my cpu is fairly tolerant (fingers crossed).
ok was using this for a while
vorkKernel-2.6.35-HAVS-BFS-BFQ-SLQB-17-Jan-11
but i found a bug and have reported it to benee.
yesterday i needed to wired tether the device as my internet was failing me.
it wouldnt connect saying no usb
flashed back to xmas edition and bingowings it worked fine
im back on xmass edition (old faithfull)
I'm using that kernel, don't use that function, so doesn't effect me... wireless tether does work tho.
