Xeneize480
This install .zip will install this yellow circle battery (credit to Tom108 for the images) for your Liberty 1.5 ROM
Also credit to ECFfighter7232 for uploading the first MOD for Liberty 1.5
I only update the 3G simbol to 4G yellow color.
This is the entire framework-res.apk from Liberty 1.5 so if you've made any other changes to the framework-res.apk this will over write them
MAKE A BACKUP BEFORE YOU INSTALL
I am (we are) not responsible for what you do to your phone
INSTALLATION (taking right from their instructions)
-boot into recovery via clockworks bootstrap
-select "mounts and storage"
-select mount /system
-go back "powerbutton"
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select LibertyX-1.5_Cir_Bat.zip
-reboot
Download from HERE
File is being host by MediaFire
Good Luck
Uploaded with ImageShack.us
Download Here if you want the yellow circle without the 4G simbol
Credit for original post ECFfighter7232
-reboot
Download from HERE
Good Luck
