rudrateja
I found a way to Overclock MT6573/Micromax A75
by searching on Google
I am not sure about the frequency. Overclocked values will not be displayed in any application. We may conform this by making benchmark test before and after Overclocking.
I don't know weather this is called as overclocking or performance improvement.
Just follow the Simple Steps.
Before doing this Make a benchmark test using AnTuTu Benchmark or Quadrant and note down the Result.
-First enter into engineering mode by dialing *#*#3646633#*#*
-Now you will get a Screen with title "EngineeringMode".
-Press on "De-Sense"
-Now goto "PLLS" >>"APMCU_PLL"
Set the value to "79" (Default is 75)
-Hit back button>>goto "MDMCU_PLL"
Set the value of MDMCU_PLL to "79" (Default is 66)
Hit the Home Button ( Don't Reboot your phone)
Now your Handset is Temporarily Overclocked to Some Unknown Frequency (May be Maximum). (You cannot check the Overclocked frequency )
Make Benchmark test again and compare the Results
Everytime you restart you phone, you have to do these steps again to Overclock. (Because the values of APMCU_PLL & MDMCU_PLL will be set to its Default when you restart your phone)
Imp: Do it at you own risk. Please don't change any other values other than this.
Benchmark test on UB2-V3 ROM
