Frank The Tank
BudGreen24 on zte warp forums posted this earlier. I thought Id try it out and to my surprise, It actually worked great.
Battery life is at least 30% better. :rock:
apps and webpages are loading faster.
http://forum.xda-developers.com/showthread.php?t=2360670
It has received many positive responses so far... But there were also several negatives as well.
I thought Id share this with you guys, I've flashed it and it works on the sequent. It works great. Im using superr rom 2 and I flashed the stock rom zip. Unless your running Jelly Beer, Cm10 or cm10.1, then flash the stock rom.
If you try it, let me know what you think. :smokingsomb:
