Root [MOD] Remove slide lock when pattern lock is set up for v4.5.596
bouchigo
Android Expert
This is for stock GB 4.5.596.
This will remove the slide lock when you have a pattern lock set up.
Stock Pattern Unlock (no CRT, Rotation, or Battery)
Stock_GB_4.5.596_Remove_SlideLock_PatternUnlock.zip
CRT plus Pattern Unlock
Stock_GB_4.5.596_CRT_PatternUnlock.zip
CRT, Rotation, plus Pattern Unlock
Stock_GB_4.5.596_CRT_Rotation_PatternUnlock.zip
CRT, Blue battery10%, plus Pattern Unlock
Stock_GB_4.5.596_CRT_Blue_Batt_PatternUnlock.zip
CRT, Blue battery 10%, Rotation, plus Pattern Unlock
http://www.mediafire.com/?ynwnrn5ddkab2gn
6/15/11
Remove Mods (if you no longer want the mods, use this to remove them):
http://www.mediafire.com/?hcg5k0dl5dilfec
bouchigo, why dont you just develop your own rom and get it over with!!
you seem to have the know-how
and i for one would rock your design all over the place!
Thanks for the awesome mods. No need for a ROM anymore.
It would be amazing if you could make a mod that will let you set the screen brightness lower and/or a lower auto brightness mod! I hate using my phone in the dark when the screen is so bright.
Quick question...I loaded the CRT, Blue battery 10%, Rotation, plus Pattern Unlock zip file. Once the phone loaded up I got spammed with force closes. Any ideas????
I just wiped cache...it did something extremely LOL. It got to the boot animation and did not boot loop, but would not finish the animation, like, The phones screen would brighten and would vibrate like it was about to cut on all of the way, but would stay at the boot animation. Any thoughts?
OH. Didn't know they had an actual term for that...that isn't the problem I have done that plenty of times. I guess maybe give me the instruction for this. I mean I thought it was idiot proof, but maybe I just proved myself wrong. LOL
Installing the zip not resetting the battery (just clearing that up haha)
just boot into recovery, using droid 2 bootstrapper,
and install zip from sdcard
then choose location (second option)
and find it.
then reboot,
but since your in a bootloop wipe cache partition before you install it, DO NOT do a factory data wipe, unless you want to start over again.
Bouchigo you are always a king among men... and p.s. I'm back from my vacation at the lake... ready to load up some official gingerbread and help people...
you want to help janathan, help me convince bouchigo to develop a rom!
and to set up a donate button :) cause where would we be without bouchigo?
