V SuperUser V
Android Expert
Hello everyone, I came across a theme thread recently by Mr. Pnizzle (as we call him now)and found this awesome link posted by him as well [GUIDE] ICS Style 'Settings.apk' - Make it yourself !! !! - xda-developers and I decided to make that MOD work on my phone, after all, I'm running an ICS theme so why not. The guide is fairly easy to follow so I don't think I'll be rewriting the Guide here.
The Settings.apk I used came from Idrifta's Number Two (#2) v1.5 ZVD ROM so it has most of his PNG's in it. You can always replace those PNG's with your own, I must warn you there are two new PNG's I had to edit and add (the guy at xda provides them) to the drawable-hdpi they are called ic_settings_bluetooth2 and ic_settings_more.
NOTE: The font color (ics blue in my case) shown on the pictures/video will not override your current font color, whatever you font color is before you replace your Settings.apk should stay the same.
EDIT: 5/9/2012
-Rearranged the APPLICATIONS section a little
-Created a section for BATTERY (Batter use)<--Thanks Idrifta for the idea
-Still working on the Toggles
download it
here: v1.4 http://dl.dropbox.com/u/51753039/Settings,applications,battery/Settings.apk
screenshot:
Just so you know i did not rearrange the order of other sections because most of us are used to the stock layout of things within the Settings, but i can rearrange stuff upon request![]()
EDIT: 5/8/2012
-Added a section for APPLICATIONS alone
download it
here: v1.2 http://dl.dropbox.com/u/51753039/Settings Applications/Settings.apk
screenshot:
EDIT: 5/8/2012
-Still working on the Toggles (WIFI, BLUETOOTH)
-I moved Battery Use out of Applications Settings,
download it
here: v1.1 http://dl.dropbox.com/u/51753039/Settings Battery USE/Settings.apk
and a screenshot of it:
another icon was added (actually, copied, resized, and renamed): ic_settings_battery2 <----for themeing purposes![]()
My first attempt at this MOD, and a video of the finished product:
download it
here: v1.0 http://dl.dropbox.com/u/51753039/ICS Settings/Settings.apk
Instructions: download your favorite mod and push it inside /system/app using Android Commander (preferred) or you could just put it inside your SD card and copy and paste it inside /system/app using your favorite File Manager
I'm experimenting a few other mods based on this one, I'm trying to get the wifi on/off check box under the Wifi settings and little things like that so i will update this thread as i go![]()
Thanks to:
-balamu96m for making the guide over at xda
-Mr Pnizzle for the link
-Idrifta, for providing my base Settings.apk
