Root [MOD] *updated 5/9* ICS Style SETTINGS.APK
hey nvm that pm, i got the toggles working :D but cant get data.. :( not yet anyway lol once i find the checkbox code for it we will be all set haha but anyway here's my modded version if ya wanna check it out..
it's a flashable zip, cuz im cool like that lol
ICS Settings MOD
ICS Settings MOD
I checked your settings.apk, and i think you failed like me lol, i was only able to get a checkable check box but it didn't enable anything. We gotta do something :banghead:
I got it. I had to uninstall. Then delete the apk from apps instead of just copying over it. Strange. Im at work or else I would have used commander.
But i got it. Love it dude.
What else does ICS have that can be ported over ? I have camera, ics doggie file explorer, launcher, settings, etc..... What else is there?
I found a problem. My home button and search soft key isn't working at all. I tried changing some shit in settings but nothing. Any thoughts?
It was working with the first one.
*Sent from the Ghetro PCS Esteem*
Also sound and airplane mode is gone from the power menu.
Okay i flashed the 2nd one, wifi. That was the one i got working and disabled my home button and power options.
I went back and flashed the 1st link,apps link, and everything is working normal. So you might wanna check the 2nd, wifi, link.
Out maybe its just my phone idk. Figured i would point out anyways just in case :D
How did you do it? Explain in details please... lol I'm kinda slow when it comes to this..
First make sure you have a backup of the app. Then uninstall the app through titanium. Then navigate to system/apps and delete settings.apk. Then copy and paste the new settings to system/apps and reboot.
Or just push it with commander.
First make sure you have a backup of the app. Then uninstall the app through titanium. Then navigate to system/apps and delete system.apk. Then copy and paste the new settings to system/apps and reboot.
o.0 maybe u made a mistake but y delete systems apk its only settings.apk lol
Lol you knew what i meant. Their ain't a system apk lol
*Sent from the phone better than the LG-Connect*
Idk what yall talking about :p, and I've been pushing all of them with commander and everything works over here.. No uninstalling, or reboot, and or TB needed, just push and done
Edit: actually there is some rebooting needed if you're copying and pasting using a file manager
dammit!! haha i just realized that lol well it was close haha we try again :D
I think if your not using commander you have to uninstall. Commander takes care of all that for you.
I didn't have to uninstall anything. Root explorer>copy>paste>reboot. Done!
