frenchy714
Android Expert
I take no credit for this mod. -Frenchy714
What does this do?
This mod will help to increase your battery life by lessening the draw of power the CPU can use. With HAVS, there is a voltage range that a certain CPU speed will use. These scripts lower both the MIN and MAX voltage at each speed, even if your kernel is already undervolted.
Kernel developers make their kernels to be "universal". By universal, they want the kernel to work on as many phones as possible so they mildly undervolt. However, some phones can handle a more aggressive undervolt. Some can't. These scripts will help you see if your phone can be undervolted more for better battery life.
The -25mV and -50mV undervolts should work for almost anyone. The -75mV and -100mV are pretty agressive and might not work on your phone. If you get reboots or freezing, try the .zip that is 1 step down and see if it is more stable.
If you would like to learn more or try, click here.
To those of you who try this out, please make sure you post your results and experiences. Thanks.
What does this do?
