if you wanted to i could put them in a shared folder, send u an invite, and you can put them in your public one and post links, doesnt matter to me.
the suspension only blocks my public links
Or maybe I'll upload them to google docs
I have a FTP account that translates to direct HTTP links with no limitations. I can create a folder and host them there for you?![]()
That'd be fantastical. Can u create a folder for me and make me a login to that dir so I can just up to it?
Shwew Thanks... haha I hate the Stock ROM, and Im connected to my PC via USB, faster to transfer.Hold tight. Uploading that one now.![]()
Thanks, I am installing boostupdate.zip from .zip in cwm as we speak, have a screen with S/W Upgrade Please Wait while upgrading.. Then I have the MB v1.2zvc.zip to flash and should be good..I used the newer one Monster made that just had ZV4 and CWM/Root. (So not the boostupdate.zip file) It's the one that has _inc at the end of the file name.
By the way. Updated my post with the download link.
I still have 3 of the files that I download from monster's file host before it died. I'm uploading those as well:
LG855ZV4_21_inc.zip
MarkyBeatsLITE_edited.zip (Modified Lite version of MB that PlayFullGod made some changes to. Refer to the MB Lite thread for more details on that)
MBv1.2BSTzvc.zip
I will update them to links once they finish uploading.
Yup, already wiped data/factory reset, and currently almost done installing MB v1.2zvcLooks like it worked for you. Since you got far enough to see that screen.![]()
I agree, I am liking 90%+ of what |Monster| has created here! Has a few kinks to iron out, but hopefully will be back to running perfectly again.I did give the new version of MB a quick look before reverting back (since phone wasn't activated). The theme does look better then the old one and the color scheme is starting to mesh better with the rest of the UI. I say it's moving in the right direction.![]()
