Root Monstro's Rom v3 SM-G360T & SM-G360T1 5.1.1 Fastest and Lightest Rom 6/12/2016
I went back to original firmware just because I wanted to see if I could. Then I used the usb drivers from http://www.samsung.com/us/support/owners/product/SM-G360TRWATMB# scroll down to drivers. Then used Odin to push TWRP (I had to remove the .md5 extension from the op), then installed rom from sd card, selected not to install SuperSU, phone rebooted, went through half dozen boot sequence loops, then booted. Went back into recovery and installed gapps. Much smoother this install and was able to do it from Win 7 64-bit.
First boot always takes forever
is slimpickins faster?
No clue
I like the ROM but its still missing ah few things. For instance. U can't set lock screen wallpaper from main settings. No volume or keypress sound. Plus the ROM itself will partiton ur ext-sdcard. I didn't understand that part if it suppose to be the lightest ROM. I think I'll stick wit slim pickins until this ROM becomes more stable.. But all in all dam good ROM for speed.
No need for 3 wallpaper choppers, easier to just go to the pic you want and set it
all sounds have been removed, not needed
never had it do anything to any of my sd cards
My rom has been more stable then Slim
V3 Uploaded
Fixed: The Dialer\Contacts Issues with force closing
Added S6 Ringtones and Notifications By Request
Fixed isues with sd card not mounting
Sorry forgot to add fixes
yea it is to me. i mean i didnt have to go thru the lil things that i have wit this rom. so now ive tried the june 12th update and now supersu wont update. idk i follow the same procedure everytime to install and it boots fine(oh yeah i like the knight rider btw)and everything. its juz when i get to setting up my phone something goes wrong or it dont work.. i would run this rom everyday if i knew everything would work properly at once. thanks juz my opinion..
I'd suggest just stay with Slim Pickins . dont know the lil things you have to go through, out of the 500 people running this your the only that has had problems
i did a fresh install and SU updated fine
Does this work well on G360T? I know most people are using the G360T1, also is it possible for slimpickins to run on G360T? I am also rooted
hey grandamle91, I realized you miniaturized the system icons and font.
Might be a noob question, but how do I change the size for both (if there is any way)?
And u know wut I will. At least wit slim I don't have to go back and reflash anything after I've installed. Ur updates are off and it seems slim update a lot better. No supersu problems no contact problems or play store problems. I'm not downing ur with I've been an android user since blackberry and dude I've tested a lot of roms but neva had to go back and add stuff. Its already patched in. So do more research. I've 6 different phones to try any rom on. So thanks again for yall hard work.
these really sound like device-specific or user-level issues. i have had zero issues with this ROM. i dont know what you are "patching back in" but supersu works flawlessly for me. volume sounds work fine. i havent had to reinstall anything whatsoever. it actually runs better than stock. i dont think he is the one that needs to do more research.
Man wuteva dude. Ur not standing next to me when my phone crashes with this rom. So I did do more research and stuck wit slim no problems here..
You're right. Your phone is crashing. I'm saying it's likely your fault. I base that conclusion on the fact that no one else is having that problem. Your best bet is to ODIN flash stock ROM, bootloader, modem and recovery to restore your partitions and try again
most likely impossible because the system camera was replaced by open camera (personally I don't prefer it at all because you can't record on the front facing camera)
any idea if restoring stock cam is as simple as an apk or two? i figure the code is still in the OS and restoring that camera might restore the shortcut
Let me know if this works, Put it in the data\app folder and set permissions to 644 and reboot . open camrea can be deleted while in there
put the .jar in the system\framework
Everything Should be set to 644
