Root Monstro's Rom v3 SM-G360T & SM-G360T1 5.1.1 Fastest and Lightest Rom 6/12/2016
Hello,
I finally figured out that the Recovery which I was using is not TWRP 2.8, despite Odin confirmed it has been successfully installed.
After manually executed "dd if=recovery.img of=/dev/block/mmcblk0p17" I got correct TWRP version and successfully flashed phone.
However now, instead of booting into system, each time when I turn on the phone it boots into TWRP. How to boot into system??
Hello,
if you have flashed a switcher at any point you need to flash the restore zip for the ROM you have installed
Got it working after reinstalling boot.img and recovery.img taken from http://forum.xda-developers.com/showpost.php?p=62457159&postcount=42 with following reinstalling TWRP and flashing once again.
Is it possible to turn off music while booting? And how to check which frequencies are supported? The local 3G does't work and I doubt if this phone supports UMTS/HSPA+ 2100 MHz...
supported frequencies are determined by modem, which is initiated before the OS.
i have seen an xposed module that disables the sound at boot. you can also turn all volumes down before shutting down and this silences the sound at next boot
Hi,
after several days successful working I suddenly get 'Custom Binary block by FRP' screen after system restart. Phone does not boot into both system and TWRP, only shows this message on screen. Why does it happen and how this could be fixed?
MONSTRO'S ROM v3 5.1.1
June 12rd 2016
Build prop edits for speed
Graphic edits for fps
Nuked everything that's not needed
Lightest Rom
3g/4g edits for better speed and roaming
WIFI, USB, Bluetooth Tethering
4.42gb free internal
Rooted
Deodexed
Xposed
Supersu
Volume Mods
Only 288MB
Flash with TWRP 2.8.7.0
TWRP 3.0.1 has issues flashing
Wipe everything
Flash
Flash GAPPs
DO NOT let TWRP install SU
Enjoy
Downloads
Without Xposed
With Xposed
June 12rd 2016
Lightest Rom
Rooted
Deodexed
Xposed
Supersu
Volume Mods
Only 288MB
Wipe everything
Flash
Flash GAPPs
Enjoy
Downloads
Without Xposed
With Xposed
Is this the correct choice for GAPPs? platform arm android 5.1 variant stock
June 12rd 2016
Lightest Rom
Rooted
Deodexed
Xposed
Supersu
Volume Mods
Only 288MB
Wipe everything
Flash
Flash GAPPs
Enjoy
Downloads
Without Xposed
With Xposed
No Root
This message comes up when i try to flash recovery:
"md5 error! Binary is invalid"
i checked md5sum and it was a matched
Could you help me resolve this issue?
Thanks
June 12rd 2016
Lightest Rom
Rooted
Deodexed
Xposed
Supersu
Volume Mods
Only 288MB
Wipe everything
Flash
Flash GAPPs
Enjoy
Downloads
Without Xposed
With Xposed
No Root
I'm very happy with rom you did a great job just wanted to say thank you .
Thank you, if anyone happens to have a copy, Android File Host has seemed to lost all mine stuff and my hhd died couple months ago
I recently had to update a game on my device. Now when I try to start the game it gives me a message saying "security violation: 'xposed framework bridge' injection detected" then the app closes. I tried using the module called "sudohide" to hide the xposed framework from the game but, to no avail. Please advise on how I should proceed, I love this rom and don't want to have to go back to stock. Thanx in advance
alot of games now are checking to see if a phone is rooted, you can uninstall the xposed frame work and it should work
Fantastic ROM. However, root checker says it's not rooted. I installed the correct one. Xposed and rooted. The first time I installed it SuperSU got installed but I bricked it. Had to start completely over from Stock to this ROM. I found out that all cell phones have A FM transmitter but it's disabled. And this phone (sm-g360T1) has it in the specifications. Rooted phones can install Spirit FM. But needs to be rooted.
