I know you can use the supplied headset to pause and skip the songs but you can't go back and I don't always use the headset (in fact I hardly ever do).
i really miss this too after changing from iphone. I'm going to try PowerAMP
dont bother with poweramp... its over rated.. winamp rocks and is free
Widget locker. Allows you to put icons and any widget on the homescreen along with various different unlocker. (Like iPhone slider, stock android, Sense unlocker, Moto's unlocker) No rooting, and it's very fluid on my Desire. Not hint of lag.
It does cost though, but it's not very expensive and IMO it's well worth it.
Basically gives you a way to instant-launch apps.![]()
If i put the music app or camera app on the widget locker screen and try to access it should it take me straight to those apps or do i have to unlock first?
No matter what i change in settings all it does once i press the app is bring up the unlock pattern and THEN take me straight to it. Is this right?
hmm not too keen on simply lock screen because of the slide to unlock seems temperamental.
Is there any way you can customise what a double tap of the home button does when the phone is locked? If I could get this to somehow show audio controls then that would be perfect for me.
Peninsula, how can I get this default orange lock screen back to try to stock app lock screen controls? When i go to select lock screen wallpaper I just see the contents of my gallery as thats where my last lock screen wallpaper was from
Tikigod19 - go to Settings > Location and Security. Then select Change Screen Lock and turn off the screen lock, then exit & play some music. If you lock the screen then press home key the music controls should appear at the top of the screen. Does that work?!
