Ever since I updated my roms around a week ago I cannot use my wifi. I turn on my wifi and the icon that shows you that wifi is on isnt there. Are there any fixes to this?
Did you setup wifi? I know when i first turn mine on i have to setup the network i will be using. If you did then did it save the network info? You can try to wipe cache and dalvic see if that helps you.
