...It isn't a screen protector, just a piece of plastic to to cover the finishing as Lunch said. Every appliance/piece of technology has it.
Doubtful...given that, as stated earlier, it has cutouts for the sensors and camera, just like the aftermarket protectors.
Not all protectors are made with the same composition, in that some are harder/thinner, while some are thicker/gummier. If it were just a "temporary shipping" film, I think mine would have fallen off by now, and and would have been applied with a milder adhesive. There would also most likely be a pull-tab if it were to be removed after un-boxing.
hello hello . . I'm new on t mobile been using the galaxy 4g for 10 days but thinking about exchanging it for g2x ... does hard reset fix the wake issue & is speeds are slow even in 4g areas ? . . my galaxy doesn't like to play flash & when it does it sounds like its in slow motion can't listen to my radio shows lol .. does this device?
You can take the plastic off....In fact, I would recommend against even putting a screen protector. You know why? It has Gorilla Glass which is one of the big reasons I bought this phone. Look up Gorilla Glass to check out how awesome it is! It's a shame I'm on my second phone and it's riddled with problems.
