epicIllini
Hey guys. So my one big issue with this phone is the screen wobble. The two halves of the phone sort of "click" when pressed in certain spots. There is also an oreo effect. This made the phone seem loose and cheap. I had to try to do something about it because it bothered me a lot. So this is what I did:
What I did was I took bodyguardz protective film, cut it into strips, and stuck it on my phone. I pushed the two halves of the phone together and put the film over the place where the two halves meet. So far it's worked really well. The phone feels a lot more solid, and you can barely tell that the film is there. The downside is that you cannot use the slide out keyboard. However, the software keyboard is good enough for me.
Also, I did not use the solution to apply the bodyguardz. I'm sure if I did, the film would stick on ever better, and would probably not peel at the ends.
What do you guys think? Can you think of any way this can harm the phone?
and spread out my grip behind the phone, with my index finger almost covering the camera, it taps less when using my thumb.. fwiw.
