Haha...Nice to feel like the red carpet is rolled out waiting for me!
First of all...I just want to say that while I had a lengthy conversation with nathan312, HE made the choice for the NC...I only provided pros and cons of both devices and never gave a specific recommendation.
I truly feel like both devices offer great value!
Here is a brief rundown as I see it...
The NOOKcolor has:
- better build quality
- a better screen (higher resolution - better e-reader for sure...duh
- more RAM (512MB vs. 256MB on the Archos) which results in more responsiveness throughout
- better developer support (come on...you can already run a pretty decent 3.0 implementation)
- CHARGES OFF MICRO USB WALL CHARGER UNLIKE THE ARCHOS - hooked to a computer using 2.1 it doesn't charge but any micro usb wall charger will work in a pinch (if using 3.0 it does charge via USB cable attached to a computer)
The Archos 70 IT has:
- "plasticy" feeling build quality but VERY thin and light...easy to hold for long periods of time (trust me...the NC feels heavy after awhile)
- better multimedia experience all around (much better speakers, better video support, and a kickstand
- HDMI port (not a big deal for me...but it's definitely a pro for many users)
- Out of the box all you need to do is add the Android Market and most users would be set
It's hard for me to say which one I like better. I'm not trying to be PC about it...but I go back and forth with which tablet is a better fit. Neither one is a perfect tablet but $250 for the NC and $279 for the A70IT...it's hard to go wrong! Just depends on what is important to you. The NC takes a little more hacking to get it set up...but has MUCH greater development support so the possibilities are greater. The A70IT is a MUCH better multimedia device (although Flash is a bit lackluster on it).
Just my opinions here. If I didn't have both devices available to me to play with...I don't know which one I'd go with...but once there is a 100% stable version of Honeycomb running on the NC...that decision would probably be easier
