Help Need a little help...
Tbsf79
I currently use the ZTE Merit, and I have a few questions. 1. My app space is limited, how do I improve it. 2. The battery life for my phone isn't good, is there a solution? 3. My phone just started posting "Network error, please check the network?"
I've tried other places to help with my questions, but this forum here seems to be better. Also, this phone is perfect for me other than the little annoyances posted above.
Any assistance would be greatly appreciated, your phone dummy, Tim...
P.S. Straight talk costumer service is sketchy, I not good with heavy Indian accents. Lol
Hello TBsf, welcome to AF! I have moved your question to the ZTE AT&T Avail forum. ITs actually the same phone you have, and if you browse the forums, lots of Merit specific questions are in here. Thanks for understanding, and for joining up! :)
1. The only real effective way to free up space is:
-root the phone
-remove bloatware (carrier specific apps)
-Flash Clockworkmod Recovery
-Wipe the dalvik-cache (in recovery:advanced>wipe dalvik-cache>yes)
-reboot the phone and enjoy.
without root:
to save battery:
go to settings--accounts and sync--uncheck background data
use your task manager to kill apps after you get done using them.
keep your wireless and bluetooth off if you are not using them
i generally get 36 to 48 hours on a charge
without root:
to save space:
move all apps that will let you to the SD card
don't update stock apps
only update apps that can be deleted by uninstalling them and then downloading the new version from a free app market that is not google play [slideme market is the best]
with root:
to save battery:
do all of the above
get a free app killer--like advanced task killer free
remove your stock apps that you do not use
with root:
to save space:
do all of the above
also delete all stock apps that you don't use
Do not use an app killer. It will make your problems worse.
You can also leave GPS on. It doesn't use power unless an app is trying to use your location
