Hey guys,
Been wanting to verify that this will work for Evo V. I tested it for the Sprint Evo 3d and all went well. I need someone willing to dump mmcblk0p3 per the instructions in the first post of this thread:
http://androidforums.com/cdma-evo-3...ng-someone-adb-experience-unlocked-hboot.html
There is no risk, someone just has to be willing to take 5 or 10 minutes to do it and upload to Dropbox or something so that I can check it and make sure it will work with Evo V. S-on/off does not matter for this but you need to have an unlocked bootloader for me to be able to check the memory block when you're finished.
If it works then you will be able to use flashable zips to lock and unlock the bootloader whenever you want (s-off required; though most of you are) which you can read about in this thread:
http://androidforums.com/cdma-evo-3d-all-things-root/662615-how-change-your-lock-status-flag.html
There is no risk in doing this. The risk would be flashing the zip to see if it works without looking at mmcblk0p3 first. So anyway, someone please do this so we can finally find out if it will work with the Vvo
