10 minutes on the white screen. when would you guys pull battery? 1 hour?
how long is reasonable before i should pull batt etc?
i can nand, but cannot go forward with any new roms.
so being stuck on the white screen for 10-15 minutes is normal?
it never goes into the boot animation, it just stays at that white screen.
i'm nand restoring back to cyanogn tazz 1.0
i have been able to attain root, flash so many roms. but lately it won't work. its not like i don't have any experience with this, but this is a new development and i cannot figure out other than hardware issues.
).How are you getting the zips to your root folder?
Which ever way it is, try another way in an effort to isolate the problem in the chain of events..
..for example, if you're downloading the zips to your computer and then dragging them to your / folder after connecting the USB cable, try downloading the a zip to your phone and then going into Root Explorer and moving the file from the download folder, or which ever folder the zip arrives into your device, to the / folder..
..then (with a fully charged battery, 80% at the least) power down and flash that zip.
[FONT=Courier New]Step Start-Time End-Time[/FONT]
[FONT=Courier New]------------------- ---------- ---------[/FONT]
[FONT=Courier New]Nandroid backup 12:26 12:28[/FONT]
[FONT=Courier New]Wipe data/factory reset 12:28 12:28[/FONT]
[FONT=Courier New]Wipe Dalvik-cache 12:29 12:29[/FONT]
[FONT=Courier New]Flash .zip 12:29 12:31[/FONT]
[FONT=Courier New]Reboot (3 skateboarders) 12:31 12:32[/FONT]
[FONT=Courier New]CyanogenMod boot animation 12:32 12:35[/FONT]
[FONT=Courier New]Setup 12:35 12:36[/FONT]
This is the same type of behavior my phone had when I tried a 32gb card, it would do half of about any process and then crap out. It sometimes booted - sometimes not, it sometimes could see what was on the card (or not), it took me several tries to get a ROM to flash (any of this sound familiar?). So I'm wondering if the card is somehow bad or going bad, has a bad sector (or whatever the SD card equivalent is to a sector). You mentioned that you reformatted your SD card, did you do this via phone or PC? Regardless of the answer to that question, try reformatting using the other one. I'm also wondering about doing a full reformat (not 'quick') using the PC.
Alternately, if one is available to you try another SD card to see if it behaves.
scary alien said:Okay, I installed the ROM with no problem (went pretty fast, actually):
Code:[FONT=Courier New]Step Start-Time End-Time[/FONT] [FONT=Courier New]------------------- ---------- ---------[/FONT] [FONT=Courier New]Nandroid backup 12:26 12:28[/FONT] [FONT=Courier New]Wipe data/factory reset 12:28 12:28[/FONT] [FONT=Courier New]Wipe Dalvik-cache 12:29 12:29[/FONT] [FONT=Courier New]Flash .zip 12:29 12:31[/FONT] [FONT=Courier New]Reboot (3 skateboarders) 12:31 12:32[/FONT] [FONT=Courier New]CyanogenMod boot animation 12:32 12:35[/FONT] [FONT=Courier New]Setup 12:35 12:36[/FONT]
Total time: 10 minutes
Don't know how illustrative this is, but at least now ya know.![]()
Pulled battery, pulled out the sd card. Rebooted. Now it hung on the white screen for about 3 minutes. Then went into the boot animation. It's been spinning on the boot animation. Round and round.
Hasn't gotten to the set up portion yet. Been at least 6-7 minutes on the boot animation (double of scary aliens time table)
I know this sounds strange, but it's fixed a problem for me before...
I know this sounds strange, but it's fixed a problem for me before and proved (to ME at least) that a wipe/factory reset is really not the same thing as a factory reset.
Try doing a factory reset. The instructions below are swiped from Frisco's factory data reset thread.
- Shut down your device.
- While holding down both the volume-down toggle and the send or "phone" button, press the power button.
- Wait a moment, and a screen will come up: read the print completely and follow directions, it'll walk you through the simple process.
if this doesnt work pull a logcat for us and we can get an idea of where the flash is failing and go from there
Thanks for trying.
Pretty strange, really - I wonder if HTC did different builds with different hardware.
eu1
