Root Need help! -(About Update)
kevinrubio
Android Expert
YouTube - How To Upgrade Huawei Ascend 2.1 To 2.2 Tut
So i found this tutorial and followed it and it was successful for me, and now i have android 2.2! But then i read from somewhere else that says ----->
You will get a NO UIM CARD error is you re-download titanium backup, please dont open clockwork, titanium backup or z4root once froyo is installed. IT WILL BRICK YOUR PHONE. However there IS a fix. If you get the error, msg me and I will give you a link to reverse it."
Is it true i can not re-install titanium backup nor z4root?
this 2.2 is a POS...dont nobody install this, if you want 2.2 install cm6 it is 2.2 froyo...cause any other you will get the uim error...just a warning...
so the one i have is not real or whats wrong, because i did not get any message when i installed z4root again.
is it cm6 you have install? and btw none of the 2.2 are official...plus the one from the video is not even overclock, cm6overclock to 710mhz...
oh okay and i am not sure, if i didnt get the message then it has to be i guess?
yeah, but you would hate to be in a bad cituation and your phone decides to have a uim error and you couldnt call for help...i had install that also before cm6 or cm7 had came out just totest it and a couple of days had got the error...
First off pardon my language.... this is the shittiest video recording I have ever seen....Lol! Secondly do not dl this please use Cm6 or Cm7 as they are stable roms... sorry for the late post but I hope this helps someone!!!
oh can you give me the links to cm6 and cm7 please, i dont want to break my phone
yea i know lol and okay can u give me links?
whats cwm??(i would love a link for it), and thanks so much for the links. Can you update it form the filmware i have right now?
Here is the one I use, it is 2.5.1.8 which can be used for Icarus and all other roms..... May I make a suggestion.. Maybe you should read a little bit more of the forums before you try any flashing. I dont recommend you try any of this unless you fully understand what it is your doing.... Im not trying to be rude,I am just trying to help you out a bit:D:D
CWM Recovery.zip.
on CWM use the version that rom manager installs. One its easier for you to install, two isaac no longer supports anything other than 3.0.0.5.
Other than that everyone has pointed you in the right direction.
how do install a 3.0.0.5. CWM? i have downloaded rom manger and dont see it
