PlayfulGod
Extreme Android User
^^^ twice, once downloads, 2nd time will install it.You click the very first option, Flash ClockworkMod Recovery.
thos the files you going to need to install cm7...![]()
press the one that says metro until it is highlighted
it only shows cricket
Flash metroff 1.3.. Link is on the cm7 wiki. Metro will be on there afterwards.. Flash the same way as cm7 and gapps through cwm recovery..
okay i have done that now after i have edited it, it disappeared
You shouldnt have to edit it after flashing it, at least I didnt... I believe if you hit menu and restore defaults it should come back.. Otherwise reflash metroff, then just highlight it and make sure the button is green, reboot, should be in business..
the button is green, but when i hit back it dissapears, so just reflash it?
yes: MetrOFF-v1.3-MMS-GB-Edify-CM_ASOP-No_Roaming_indicator_Off_signed.zip after you flash it, you shouldnt have to mess with apn.![]()
Downloading what? Things from the browser?
Market, when its not wifi
Ohh yeah forgot you guys are still stuck on that.
Yeah i don't think i will ever get a contract again. I had sprint for a few years and i know i will never go back to them.
Thats not the rom its your 3g it has nothing to do with the rom.
oh okay
