Hey guys, I have a problem and I need a quick response. I rooted my HTC EVO 4g a while back, and I did a factory reset. Now when I turned on the phone and let it start up.. I get a HTC Sense force closure. How do I get rid of it? Did I brick my phone?
I do not have Wipe Dalvik.. Im on ClockworkMod Recovery v3.0.0.5..Boot to recovery, wipe cache and wipe Dalvik cache, reboot
Do I use Wipe Cache Partition or Wipe Data/Factory Reset?
Thank you for your help!
I just did those 2, and I'm still getting the HTC FC error![]()
Are you on a specific rom?
I'm not on any specific rom.. I just rooted a few months back, and didn't swap out roms after I rooted. I got Hboot 2.2, and on Clockwork.
Would going under the Backup and Restore under the clockwork recovery mode help anything by any chance?
If you made a nandroid backup, you could try that. How recent is the nandroid?
I'm afraid that backup is a few months old.. but I haven't flashed any roms or anything after that backup. I tried to fix permissions, but it didn't do anything. It still keep getting the constant FC on the HTC Sense.. it's like a loop basically..
I'm also stuck between a rock.. Should I do a wipe data/factory reset under clockworkmod recovery? or would that be digging a deeper hole?
Well, bad news guys.. I tried backing up the older image file, but it wasen't there. I'm running out of options.
Woah!! It workedd! Thank you ocnbrze, and andygu3 for all your help and hardwork! During the process, I got to learn more about flashing roms and recoveries. Thanks for your help guys!
So I was looking through themik roms official website, and before I rooted, i was on 2.2 froyo.. would it be best to flash the rom to their MikFroYo4.6x rom? or stay with my MikG2.5 rom?
There is nothing wrong with the MikG2.5 rom that I'm on, but I was wondering if I was supposed to put a froyo rom with my 2.2 froyo.. If so, I already created a nandroid backup of my system and ready to flash. But if I'm okay with what I got, then I won't bother![]()
