ok so im fully rooted and have su permissions. i have amon ra 2.3 rom. what do i do from here. is their any apps to save battery life like i been seeing on here. ex. people saying their battery lasts 30 hours on 1 charge. do u think i should lock it back with s-on in case if i need to take it in for repairs? if so will i still have root ans su?
First of all, I would get yourself on a custom ROM. MikG3.11 is very nice. It has an upgraded version of the sense interface and other mods like a hacked sprint hotspot.
Custom kernels play more of a role than apps as far as battery life goes. Once you get set up with a custom ROM we will worry about custom kernels.
As far as getting S-ON... no, don't do that yet. S-ON isn't enough to fool sprint into not knowing your rooted (Ex-Your H-boot version has changed, you have a custom recovery, ect). It wouldn't hurt to download the S-ON file and the RUU for later use, but don't use them.
MikG download link:
http://bit.ly/xyKhAh
Superwipe Download link:
http://dl.dropbox.com/u/63060876/ZZZVR_SUPERWIPE.zip
To install:
Reboot into Recovery
Make a nandroid if you haven't already(if you have continue)
Select wipe
Wipe everything except for SD card AKA wipe data, system, boot, cache, dalvik cache, SD-EXT and SD-android-secure at least once each. 2X to make sure they're good and clean
Back out to the main recovery menu
Select flash zip from sd card
Choose zip from SD card
Flash the superwipe file
Flash MikG3.11
Hurayyyy
