i think so , clockwork mod recovery 3.2.0.1 i think. its the newest backside iho rom .Did you wipe everything in recovery? Minus the sdcard. What recovery are you using?
i tried putting it into recovery mode but the screen just goes black no menu nothing untill i pull out the battery it will load backside iho and freeze on the android with spining green loopI had this same problem at first. go into recovery, wipe cache, go into advanced, then wipe dalvik cache. then go to mounts, and format: system, cache, and data, then reinstall your rom and you should be good to go![]()
AndyOpie150 knows how to fix it. You should send him a PM.
