http://androidforums.com/showthread.php?p=2582619Thank you for your overall contributions to the forum. I was searching around and I seem to have the EXACT issue as the Thread Author, on my Samsung Gravity Smart phone (rooted, uninstalled factory apps, including "samsung launcher", tried to flash a custom rom after partitioning sd card with unsuccessful result) and now even tho Google Play recognizes online that I have Launcher Pro installed, the phone still goes straight to a all-black blank screen with only the status bar visible, not letting me set it to USB debugging mode, or anything. SAME EXACT PROBLEM as the gentleman who created the post.im gonna send you a pm
blaxican25,i sent him a link to a launcher in a message it should pop up in his notification where he can go right to the market and install it.
I also had found out my wife went to ATT for apn setting issues and the guy there hard reset her phone and it got the same issue with the atrix 2. i also rooted because i was waiting on an ics build for it.i sent him a link to a launcher in a message it should pop up in his notification where he can go right to the market and install it.
she should have consented with me before the guy started messing with the phone. Seriously who would hard reset a phone for apn settings all you have to do is go to settings, wireless settings, apn and hit the menu button to create new apn, why do they work there? Anyways please help!!!!Its because the factory apps are deleted. Try using Android commander. Open commander and boot the phone up after you plug it in. Usually regardless of what mode you are in, commander will see the phone. From commander you can install stock apps or access your sd card.
Only thing i can think to do.
If you can install a launcher you will beer good to go.
i have the same problem like yourshow did you fix it?
Hi, I am experiencing similar problem the OP had:
Setup Wizard
Sorry!
The application Setup Wizard (process com.android.setupwizard) has stopped unexpectedly. Please try again.
Here's how it came about:
I rooted my phone. Flashed CWM 5. Flashed Cyanogenmod 7. After reboot and past logo screen, I got to the main screen, where the Setup Wizard message kept popping up, with black screen in the background.
I have a Galaxy S5830M. Advice will be appreciated. Please help!
Note: I can still connect the phone to Kies and access my SD card.
